Engine Harness Wire Size
Winona, Mississippi
Researched the threads and found no info. Looking for the size of wire used on the ground side of fuel injector plug. We have misfire on cylinders 5 and 6. Ohmed out injectors and they are good. Checked voltage on injector plug and no voltage. Put ground side of meter on manifold and positive lead of meter to plug, and voltage showed. So we believe the ground wire on injector plug has a short. Plan to replace wire, but do not know gauge of wire to use as replacement. Just wondering if anyone knows the gauge of wire used by Toyota in wiring harness for injector wires.
thanks for any suggests on how to repair or fix.
Also, do we need to replace intake gaskets if we have to split manifold.
The 6 injectors all receive +12V as a constant DC level. So, with ignition to On and engine off you should measure +12V on each injector positive side The 'negative' side each injector runs to the ECU (6 individual channels). The ECU pulses the 'negative' side to ground to activate a specific injector. This pulsing is performed by an electronic driver that is part of the ECU and controlled by the ECU to fire a specific injector at the correct time.
I'd assume you've checked for shorts in the wiring harness that runs against/near the EGR and also where it runs to the ECU behind the glove box area?
cheers,
george.
We checked the voltage at the plug. so we need to check continuity from the plug at the injector, to the plug at the ecu.
Any more guidance on how to test the wires. Also, what is best way to test voltage at the plug?
Search for misfire and EGR and you'll find plenty of pictures showing the harness areas to inspect. It is somewhat common for the clip that holds the injector harness away from the EGR to break and then the harness sits on the EGR where it melts and shorts occur inside.
You can check my writeup for when I had a #6 misfire (dead injector), but it'll take you through the various debug steps.
cheers,
george.
Thank you George. The funny thing I did not mention is that both #5 and # 6 cylinders are down.
I’ll search for your write up..
when I put volt meter on plug, I only get 8 bolts. Is that an issue?
Is there a spot where you can splice the plug at junction E21?
