Engine died while driving
Orcas Island, WA
The starter cranked but the engine wouldn't fire. I disconnected the neg battery cable, reattached and it started. I did my errands and on the way home I hit a bump in the drive way and it died again. Unlike the first time, I haven't been able to get it to started again. I know it has to be electrical, where should I look?
I'd check that battery cable, but it's more a hunch than a diagnosis. It could be that the other end of the cable where it's grounded has an issue and when you reattached it the first time, it jiggled the flaky spot looser?:confused:
Generally, clean your cables and check continuity.
Strange things like this can happen and the solution may not be obvious. The Rodeo I used to own would hit a certain pothole on I-70 in the middle of Missouri going to Colorado once a year. The motor would die. I would turn the ignition to OFF, then restart. No problem after that, but it took about three years to figure out and confirm the "issue".
The solution?
Drive around the pothole. Once a year.
MDOT eventually fixed the pothole and the Rodeo was fine after that.
Now we have an 80 and we're fine.
would it actually be battery related if the vehicle died while it was running? I've seen people take the battery completely out of a rig while it was running and it didn't affect anything. I wonder if by disconnecting it you actually reset something - hence it allowing you to restart. ( I am not by any means an electrical expert so just thinking out load ).
I'm sure the real experts will chime in for you.
Running without a battery is bad bad bad. The battery acts to balance out the spikes and drops the alt puts out. Without it, the electronics see everything from 11v to 14v, which can ruin them in a hurry.
A bad battery can also not absorb those spikes, which can kill stuff.
When it died, did you lose ALL power, or did you still have lights, accessories, etc. ? Knowing that may help narrow it down.
Did you replace / check any of the fuses at that time?
I'd check the EFI fuse in the DS engine bay fuse holder, but if you didn't replace it, it wouldn't have fixed itself. 80's are good but not that good ;p
If the EFI fuse was bad and you replaced it, check the wiring harness as it runs along the frame near the front driveshaft to see if its come loose. Mine rubbed through on the driveshaft and would intermittently blow the EFI fuse until I fixed the harness.
Dan.
Wouldn't it be nice to get some details on this truck before tossing out suggestions?
What is the country of origin?
What is the year?
Let's start with the basics shall we. Diagnosing the EFI circuit on a diesel is going to be different than on a 3FE.
Sounds like a fuel pump relay may be gone. Search on this (or FPR as they are affectionately known) and you'll find a lot of posts by folks with this problem. Seems a lot of them are starting to go now.
There's an old thread by landtank on cleaning the relay with a matchbook striker (or burnishing tool if you have one), though as important as this component is, I'd get a new one and only use a cleaned one as a trail spare. Cost of a new one from CDAN is roughly $80.
Orcas Island? Nice place :)
I agree with Mr. Held -- it would be helpful to know the year so as to better diagnose the root cause. We can assume that it's a gas engine because diesel 80s are pretty darned rare in the U.S., but you could one of those few lucky ones... :D
My first thought would be to check the EFI fuse, but as already mentioned, it would've fixed itself after the initial failure, but it could be what your issue is now. If you have a 93 or 94 model and your EFI fuse keeps blowing, you could be experiencing a problem with the wiring harness shorting out against the firewall -- I had that happen to me when I owned a 94.
Check the fuses...check the EFI relay...but definitely let us know the year of your rig and what engine type you have (i.e. diesel or gas).
My rig is a '96 FZJ 80.
Orcas is a cool little island. We have a great spot about halfway up Mt. Constitution. We can see Anacortes off to the left and Victoria/Sidney B.C. on the right. On the clear days Mt. Rainier can be see at 10 o'clock.
