I'm trying to figure out if my motor is at its end
I compression tested the cylinders
8 (100) 7 (62) no change w/oil
6 (100) 5 (44) then (50 w/oil)
4 (108) 3 (112)
2 (120) 1 (60) no change w/oil
I didn't "warm" the motor before the compression check. Problem?
It's a 350 (V1219TMT)
Double hump heads
Flat pistons and HEI
Motor installed by PO -- Circa ~ <1991
No antifreeze in the oil and no oil in the antifreeze
It burns a little oil ~ 1 quart every 2 months -- DD
I'm thinking valves but i'm out of knowledge (only book smarts) when it comes to valves. I haven't taken the valve cover off yet to check anything....
How can you tell if the valves are FUBARed by looking at them?
I did blow a head gasket in 98' -- professionally replaced
Thoughts?
Cheers
.I compression tested the cylinders
4 (108) 3 (112)
Double hump heads
Thoughts?
Cheers
load of exhuast coming from my oil filler neck
. Now I'm leaning towards bad exhaust valves.... and a new motor (which is inevitable). Gonna do the leak test before I get too froggy.
