For all the people trying to find a solution to rough running under, I have made a discovery.
Where the main engine harness comes off the firewall it is routed very close to the EGR pipe. As the engine torques under load the harness is push against the pipe. After many miles, 337,000 on mine, it wears through the insulation on the wires. Never creating a complete short to ground, things do not quit all together. Random missfires, general rough run when momentarily wet, etc. Rerouting the harness in front of the heater hoses, removal of plastic mount required, and tying away from the EGR has solved the problem. I added an extra degree of protection with a length of slit hose around the harness. Hope this helps someone.
