I came back from shopping, parked the truck and pulled the engine cut off knob and.... nada!
Turns out that the cable broke just behind the pull knob.
So I checked the EPC to figure out which components were there and how it fits together before I started pulling stuff out which would be unnecessary. So I searched for "cable" .... and I get a list of all the cables used in a Cruiser but not the one for killing the engine.
I searched for "fuel cut off" and was directed to the lever for shut of. I finally found the cable and it is called: WIRE SUB ASSY - STOP FLEXIBLE! All cables are named cable but only this one is called a wire. Funny people at Toyota.
Anyway, I took out the ashtray, loosened the big nut on the back and took it out of the dash. The cable (sorry: wire) is a complete unit (78504-90304) and is about $42 as I found out.
A bit to expensive to my taste so I called a friend who repairs bicycles and jet ski's and asked him for a piece of cable and two screw-on barrels (if you call them that) and made my own replacement cable (sorry: wire).
While I had the "BUTTON ASSY STOP" on my bench I decided it was a good time to clean and grease it. So I loosened the BIG chrome ring and pushed the shaft back and was very, very, super very lucky to catch the two tiny "locks" that jumped out when the spring came out. They look like flintstones for a Zippo lighter but are a bit smaller. I cleaned the unit, lubricated it and put it back together. Made a new cable by attaching one barrel and test fitted it on the knob side.
Back to the truck, installed the push - pull unit with the half finished cable, wiggled the other end in the "old" outer cable, and directed it to the cut off lever. Attached the second barrel, test fitted for the correct lenght and minimum play, made a tiny adjustment and put in. Put back the safety clip and it works like new.
time: 1½ hour, costs $2
Rudi
Rudi
