engine cough
Texas
My 2F coughs sometimes when shut down and warm. It sounds like it's coughing back thru the carb and trys to keep running. I can't remember from my past mechanic jobs what causes that.
thanks for help.
I had a similiar problem with my rig. I've got a 71 and I know there's some diffences between the years but it was my seloniod on my carb. I was informed that the seloniods function was to shut off the gas flow to the carb.(key is off) switch in my cause was not working correctly. This problem wasn't a big deal in my case because it would only happen seldomly but now that it's fix i haven't had the problem since.
I'm not to sure how to troblemshoot this problem but this was my experience and i'm sure there could be a multitude of possible reasons for your specific case.
good luck
High idle, advanced timing and heat all play a role.
Try turning your idle speed down first.;)
:cheers:
