Engine coolant ruining transmission?
Asturias(Spain)-London(England)
Website
www.sybaris-expediciones.com
Hello.
I just talked with the guy that rebuilt my transmission last time to tell him I had solved the overheating problems reconnecting the stock transmisssion oil radiator (the one that runs into the engine cooler).
He told me to be very careful and check the state of it, cause, on his own words "I don't know in the Toyota case, but we have repaired LOADS of Mercedes and BMW transmissions caused by a corroed oil line breaking into the engine cooler and coolant entering the transmission"
He said the water into the transmission leads to a complete rebuild without doubt.
Have any of you experienced someting like this in your automatic trucks, or have heard of anyone that had this problem before?
The in-cooler lines are made of stainless steel, but he said even that can be corroed by the coolant.
If your that worried about it, buy a new radiator from Toyota and start from new on the corrosion process.:D In my years of working on vehicles I only remember this happening once and never seen it on a Toyota. IMHO this would be one of the last thing that I would worry about.
There were a few cases (like 2) on Yotatech dealing with 96-02 4Runners, but I believe that most had to do with lack of maintenance of the cooling system.
Thank you both.
The problem is that I drained my coolant system cause it was orange from rust (not completely though) and put new coolant and after two weeks the coolant is orange again. No rust flakes or powder though.
That's why I worry, maybe that orange colour is a a clue that my coolant circuit hasn't been well mantained.
Anyway, another alternative is taking the radiator to a radiator specialist to check and clean instead of buying a new one, and take the chance to make a deeper cooling circuit clean.
Abused cooling systems will show color in the first couple of flushes. Even if thoroughly flushed it's almost impossible to get all of the residue out. With the new coolant you have a new additive/protection package doing the job, so little new corrosion, just color from the old.
Water/coolant is easy to detect in A/T fluid. It should look translucent red, if even a slight amount of water is present it will change to opaque pink. Just check the dipstick often, if you have a problem it will be obvious.
Water/coolant in an auto trans isn't a good thing, but doesn't necessarily mean trans death, especially if dealt with quickly. I have seen several with water (including mine) from successful drownings, one I know for a fact was driven several hundred miles, a couple of weeks before it was found. The fix was flush and replace the fluid, all recovered.
There is a very slight risk of the cooler leaking, but they have proven to be very reliable. IMHO their benefit far outweighs the risk.
dunno on the 80 side, but I had a vacuum leak in an Explorer that sucked the fluid OUT of the trans and burnt it up in the engine, apparently... Smoked it to the tune of $2k.
