Engine compression
Va Beach
Alrighty...I have a 78 FJ40, unknown miles on a 2F that was swapped out by a previous owner (original engine seized due to grotesque lack of oil). Anyway, I have been nursing my cruiser back to health over the last few weeks, fixing oil leaks, replacing various minor components, cleaning the goo off, etc...
Pulled the spark plugs out (they were replaced about 2 weeks and 50 miles ago) to do a compression test, #1 and 6 looked good, 3, 4, and 5 had some carbon buildup (rich mixture), but #2 looked as it did when I installed it...hmmm
Ran the compression test and got the following:
1 - 135#
2 - 0#:confused:
3 - 133#
4 - 131#
5 - 128#
6 - 114#
Whats going on with #2? Stuck valve? Any recommendations for things to do before I get into pulling the cylinder heads?
Is No2 firing? Do you have a spark at the plug?
Though this should not effect a compression test.
You have absoloutly no compression at all in No2?
Can you notice any difference when you pull the lead off No2 and run on 5 cylinders?
Valve very seldom "stick" They often burn. That or a blown headgasket (or maybe valve seat that got hammered and went away) will be you problem in #2.
Mark...
good spark in #2, no difference in engine performance whether #2 is plugged in or not...
Oh yeah, there is an obvious "dead spot" when listening to the exhaust, and a small amount of black liquidy/powdery stuff comes out of the tailpipe...
Both of the above are expected results of zero compression in a cylinder. They don't provide any additional info though.
Mark...
we went over this in class once. What brand spark plugs u running. Sometimes they don't work outta the box:eek: So you have to test them to make sure they work. Forgot how tho... good luck!
Spark plug makes no difference whatsoever to the compression test. It's removed to do the compression test. If you have zero, you have broken rings or holed piston, or burned valve. My guess is valves. Pull the head and you can diagnose all three.
I have 0 compression...pressure gage doesn't move at all, even while cranking the engine...I would expect at least some gage deflection with bad rings...
Also don't have any signs of gasoline in the oil, which I would also expect from bad rings or a hole in the piston...guess there's really only one way to tell
Autolite platinum, gapped .031
I tested them and had good spark on all 6.
For zero compression, there aren't any happy possibilities, so bite the bullet. If you put the piston up at TDC, you might be able to look or to feel around for a hole in th piston, but if you had one it would be smoking like Mt. Pinatubo. There would also be a lot of metal in the crank case. In any event, the head is going to come off for any fix.
If you can buy or have access to a leak down tester, hook it up per the manufacturer's instructions. You'll have the piston on the offending hole at TDC. Then listen on the intake end and at the exhaust pipe. This will tell you if it's the intake or the exhaust. When listening at the intake end, take off the air cleaner and listen at the carburator top.
Good luck to you!
No smoking issues? It would seem to me that you would have been having some problems w/ exhaust up to now. I'd do the leakdown before pulling anything. Have you hooked up a vacuum gauge to it (brake booster)? I'd like to see your readings
Drop your oil pan and take a look.
There's a good chance you are gonna have to get the slug pulled out and worked on. Start looking for a new 2F or research the 3fiddy conversion.
