engine compartment fan
Arkansas
I have a '92 LC with the 3FE engine and I'm just wondering if anyone knows how to confirm that the engine compartment fan works. I've had the vehicle for about 8 months and have never heard it come on. My dad used to have a 60 Series LC and we would hear it kick on frequently. I've checked in the fuse boxes and everything seems fine. In the fuse and relay panel under the hood there are slots for a CDS fan but both the relay and fuse are missing. I'm not sure if there is supposed to be something in these slots or if these are for some accessory that my vehicle doesn't have.
On the 3FE the carb fan is controlled by the carb fan switch/sensor which is located on a bracket hanging off the exhaust manifold. If you are looking into the engine bay from the driver's side its right in line with the master cylinder just about a foot lower. Its pretty much staring right at you. Its a small threaded switch with a single post with one wire going to it.
The way it works is when the bracket is hot from the exhaust manifold then the switch is closed and grounds out the fan, turning it on. When the exhaust manifold cools down the sensor then opens which cuts the ground turning off the carb fan. You should hear it go on for a few minutes pretty much EVERY TIME you turn off the truck.
First check that the wire to the sensor is even there. If it isn't, replace it. If it is then remove it and ground it to the a good grounding point. If the fan turns on either your sensor is bad or the relay is bad.
I "think" to check the sensor you have to remove it and check continuity with it cold and then heated up.
What you could do to at least get the fan running is to just ground out that wire and forget about it. What this does is bypass the sensor and just rely on the relay. The relay is set to automatically shut off the carb fan after 30 minutes.
a freind had no fan operation and it turned out to be a burnt engine harness. The harness was touching one of the air injection tubes on the exhaust manifold and it burnt through.
Might be worth a look. It was right where the harness came off the firewall and it was the tube at the #6 cylinder.
Rick
I thought my fan had a problem so I followed the FSM troubleshooting procedures and everything checked out. So I was confused until I took a drive a few weeks ago on an unusually warm day and lo and behold when I shut off the truck I heard an odd noise from under the hood. Turns out everything is fine. One quick test that will tell you if there is something wrong with the system is to put a jumper wire from the nut on the manifold temp sensor to a good ground and that should turn the fan on immediately.
