So my 95 lc engine check light came on I've put a paperclip in te1 & e1 in the diagnostic box under the hood but it's not flashing any codes!
What do I do ?
TIA
So its p0402 egr valve
Sounds good!! I'll have a look on YouTube to see what's what.Easy deal, a 4.7K ohm resister fixes that.
Care to share how and where the 4.7 ohm resistor goes ? YouTube doesn't have much on changing resistors!!Easy deal, a 4.7K ohm resister fixes that.
... the 4.7K ohm ...
Realize, he's telling you to "bypass" the EGR and fool the computer into thinking it's OK.Care to share how and where the 4.7 ohm resistor goes ? YouTube doesn't have much on changing resistors!!
TIA
Ok that sounds easy enough thank you !!!^^^ Edited
Unplug the EGR thermistor, using two .110" female spades, put a 4.7k ohm resistor on the harness side of the connector, no more code.
forum.ih8mud.com
There's no emissions hereRealize, he's telling you to "bypass" the EGR and fool the computer into thinking it's OK.
If you have to deal with any emissions stuff, this is not the right fix for you.
Do you solder the resistor to the harness?Easy deal, a 4.7K ohm resister fixes that.
