emoving front drive shaft
El Paso, TX
Love my 93 cruiser, so I decided to not use my cruiser for any trails for at least a year. I want to remove the front drive shaft for less wear and tear on the drive train. I do not have manual hubs installed yet. What, if any problems may arise if I drive the cruiser without a front driveshaft besides not having AWD?
You will want to add a CDL button if you haven't already and do the 7pin mod. You will need to drive with the CDL engaged without the fron DS installed. I don't think any long term harm will be done, but I only drove that way for about a month while my DS was being repaired.
Do you have a center differential switch installed? You will have to lock the center differential to be able to drive it.
I have the front diff out right now. My fuel economy is actually worse, and I have to keep the center diff locked or the rear axle loses power and the vehicle coasts to a stop.
The spinning of your front wheels will continue to spin the ring and pinion whether or not the drive shaft is installed. It seems the only parts that will have reduced wear will be your front drive shaft and universal joints.
If you love your cruiser, drive it on the trails and keep it happy.
I already went down this route. Removed front driveshaft and installed warn manual hubs. Mileage was not improved enough to register and the way the truck drove was different and I wasn't used to it so didn't like it. Also without the part time kit ($$$$) you'll be driving constantly with power through the diff gears that are always in one static position. My educated guess is that this will fret or abnormally wear the center diff gears somehow and when you want 4wd later they are compromised.
Also if you do get stuck somewhere there is no 4wd unless you carry the driveshaft and go to the hassle of installing it while stuck.
One last thought, rebuilt my front axle at 152k miles and the worst looking part was the wheel bearings which are still being used in part time.
My experience only.
Don't need a CDL switch, shift low range, confirm CDL lock, remove the diff fuse, shift high range, done. The CDL will stay locked, when you want it unlocked, simply replace the fuse.
By removing the drive load, wear will be reduced, yes it's still spinning, but with almost no load. That said, if properly lubed, there is little wear, not going to save fuel, AWD has better traction, handling, so what is the point?
I don't get it. Why would you remove the front drive shaft? Less wear and tear on what?
Had a vibration, removed the DS and found out that the u-joints were bad. Got the part-time conversion kit from Slee OR. eventually the shaft will go back on.
Like I write it's just for a year, I have plans to do part-time 4WD with the kit from Slee OR. Also going to be doing other mods before she'll be ready to do some light trails and overlanding. I just don't want to have the LC sitting. By the way pulled the front DS out and found out the u-joints were bad.
