"Emergency" leaf replacement for the '47
Malaysia
Hi all, ive just recently bought myself a 1985 HJ47. it sat for 3 years before i bought it and because im in the tropics, anything made of rubber has morphed into half-set glue. so while replacing wheel cylinders the other day, i noticed that the suspension leaves are in need of replacement soonish. the leaves are all eating into the adjoining leaf :vomit:
ive now come across an offer to buy some near-new leaf springs from a LJ79 and wondering if this is a good idea or not. are they going to fit? they also look like they are set up for a heavier vehicle than the stock leaves are. is there much work in removing leaves from the stack to make them a little more comfortable?
this is just a temporary fix while to buy some time to do some research and save the money to get a better solution sorted out too.
the current situation:
the springs on offer:
Measure them from eye to eye, as well as the shorter distance from center pin to eye. That will tell you if it will work.
It’s not hard to remove extra leafs, but...since your springs have already been modified (you can see the thick, non-stock leaf in the pack) I’d recommend you install the other leaf packs (assuming they measure out) as-is .
Those overload leafs look more scary than they often are. I just set a 40 on the ground today with overload leafs, and they are not stiff at all.
thanks for the response mate. is there a set range of measurements that would work for the 47 that i can look up without pulling the existing leaves off?
Measure eye to eye from the frame hanger to the shackle hanger. The replacement springs you’re looking at should be about the same length, maybe a tad shorter (until they have weight on them.)
