Emergency belt replacement help.....
North GA
Found a '97 LX 450 with lockers....one owner since '99. Drove over to Cullman AL today and bought it.
Now the typical bad part; 3 miles down the road after buying it I broke an alternator/fan belt!!!! Saw a bit of smoke from overheat and pulled over immediately. I let it cool and after I inspected it I discovered the broken belts. I'm staying with a friend tonight and the LX is parked on the street in downtime Cullman.
Picked up belts tonight and my buddy and I are gonna attempt to change the belts in the morning.
Any info or assistance on how to do this before we head out in the morning would be extremely helpful!! Lost some coolant as well but it doesn't seem any hoses were busted. Has an aftermarket cheap looking radiator cap too. Should I fill back up with premix to get me back home? (4 hours away).
Frustrated to say the least.
I believe the alternator and fan belts are supposed to be paired (ie - both bought together as a package) and replaced at the same time.
you are correct they are a paired set so they both should be changed at the same time. if you buy them from the dealership both will come up as a single part number, but you will get both
Check the idler pulley for the alt belts it could be seized up and might kick those new belts off the alternator.
Is the idler pulley necessary on the 1FZ-FE? I ask seriously. On my 3FE it just kind of got in the way. Didn't provide tension...
My buddy and I are on our way to tackle the belts in an effort to get my LX road worthy enough to get her back to North GA.
Will check idler pulley.
Can I use 50/50 mix to top off coolant??
I have read here that It keeps the belts from slapping hoses.
https://encrypted-tbn1.gstatic.com/...CpGM4Bj8wL1b-V3jpDmC_nAu4kum3qZ51Pnp-R18E-d_A
heres a pic And another! Its on the bottom there. compressor not Installed. The alt ten. pully is not there, you can see the bolt hole just below the zinc bracket at the bottom of the alternator In the oil pump cover. Good Luck.!
Good info Empty.
I dropped about 60.00 bucks for a new idler.imo it isn't because the one I took off was seized.it eat half the material off the inside belt and a quarter on the outside belt before I noticed the idler was seized.the belts don't really put much pressure on the idler at all and some 1fz guys don't even use one.alas I had(while I'm in there) on the brain and changed it anyway. Shiny metal equals sexy right lol
wait i thought you were headed to Cali ;)
I would use distilled water as mentioned above.... doubt youll hit freezing temps tonight :D
and how did you lose coolant? or was it just low to begin with. its a sealed system.... or should be.
only 3 miles and busted? did you keep driving? Just wondering if it actually overheated. If it did get hot perhaps it expanded and purged some coolant from the overflow and thats all you are missing. Where did you witness smoke? from under hood may indicate a siezed pulley or perhaps once it kicked off it got bound up and melted some belt material. From tailpipe is a whole nother ugly story.
Also if you remove idler pulley i believe you need to replace the bolt though as it leaves access to the engine internals
We can't get the AC tension pulley belt off even though the tensioner is loosened all the way up! The belt is still too tight to pull over to remove. Almost there
I pulled over Immediately when it started to overheat; we fixed the broken belt situation with all new belts and topped it off with distiller water. Thought I was good until pulling into the drive of my friends house it started to spew steam from under the hood again!! Turned it off and thought for sure it was my PHH. The PHH looks bad but I don't think that's it. It's dripping water from the right rear side of the engine. We tried to trace the water drip and the only thing I can think of is a heater core issue.....please help because I'm trying to resolve this today.
The ac normally drips near passenger firewall. On the passenger side there are also the notorious rear heater hoses. The lines are near the back of the engine and on the passenger firewall as well. I would check these. I believe the tensioner have lock bolts you have to loosen as well. Not sure otherwise why it's stuck with it fully loosened.
back right of engine while standing at bumper looking at front of motor?
there is the PHH and another hose right by it. when mine blew it was the other hose vs the normall PHH culprit
and tredwards is correct there is a lock bolt on ac tensioner you must loosen first or you may brake tensioner bolt
Just use straight distilled. You'll be fine.
