Having trouble starting the fj40, seems like not enough battery power but it reads out at 12.9 volts. i started cleaning all my connections and grounds but ended up breaking this thing. Before i go calling around to auto parts stores what is this called? I think its an external ballist resistor. Am I even close? Its sits on the passenger side fender well right below the coil and has a wire running to the coil.
Thank you all in advance again. Pup
As you can see the truck is an electrical nightmare, new wiring harness is already arrived from CCOT
