Electrical ssues
Having electrical isssues on my '76 fj40
It all began as a night-driving weak blinker/headlight issue but now has evolved into an across the board "I'm screwed" issue. Here's a quick rundown:
1) truck will no longer idle (idle solenoid relay?? not enough voltage?) Anyone?
2) Blinkers- voltage too low to blink
3) Heaadlights? "forgetaboutdit!"
4) Wipers work but very slowly
5) Oil Pressure Gage was originally working fine, then when problem escalated it was iffy, now the needle is just buried (extreme left).
6) when I turn the key to the accs position the Ammeter jumps from center to about the "11 o'clock position".
7) Horn will work
The battery and alt were checked to be ok at my local Autozone. I didnt believe it so I took it to a local garage where I was told the same. Any ideas would be greatly appreciated. The car still drives but only with the choke pulled enough to keep the power up.
Happy trails!
There are lots of things to check. Grounds are always an issue. Make sure you have good grounds from battery to frame and starter to frame. My problem turned out to be a bad voltage regulator. You can read about it here https://forum.ih8mud.com/showthread.php?t=119231 . There are lots of good tips in that thread that can help narrow your search.
Also, find a place that does free electrical testing. They can tell you how many volts and amps you are putting out while the rig is running. It can give you an idea of what may be going on.
Good luck!
spent the day working on it... pulled the instr cluster and found some pretty nasty rust/corrosion on the 12v lead to the ammeter (which is the main lead coming from the battery). Ended up having to cut the old wire terminal off and even replace the threaded stud it attached to. I tried to clean up the fuse panel a bit. I put it all back together and it seems to be ok-- it will now idle and the headlamps are currently working and not dimming at low rpm's. Thanks for your help-- I still may have a bad regulater-- I'll try and check it after I read through your link
