OK guys, Pin_Head nailed it. turns out, the black wire with the yellow stripe that goes to the insulator above the coil actually was touching the metal bracket that supports it. That said, has anyone else had this problem, know of a fix, maybe a little piece of rubber between the bracket and mount? Now though, the motor still drags when I try to start it> thought the new starter would fix that. Is it still related to ground? other connections, Fuel,? Thanks again
