Recently purchased an 74 fj40. It has been in storage for about 5 years. It cranks but doesn't turn over. No spark to spark plugs and no spark to distributor. Coil tests okay 8.65 for second and 1.6 for primary. Fuel is squirting into the carb which makes me think power is not getting to the coil. Previous owner said it started before putting it into storage. I cleaned up the negative cable ground and the starter ground. Still it doesn't crank over.
Black and White wire with red end was not hooked up to positive. i assume it needs to be hooked up. I hooked it up still no power. It looks like the black and white wire goes to the solenoid on the starter.
Also when I hook up the battery the front turn signal comes on and the rear lights.
Just to make sure the starter is turning and the engine is turning it just wont catch and fire up? That dizzy is quite dirty.
That black and white wire is for the starter but the one by the coil is actually a faded Black Yellow. Make sure this wire gives 12+ volts while cranking, it connects to coil+ also you may need a ballast resister for that coil if it is not internally resisted.
Pictures are small does that dizzy have 1 or 2 wires coming out of it?
Do the turn signals continuously flash or just go once, are the black lights just on or is that turn signals in the back as well? if so hazard switch could be on
Yes distributer is dirty. Any suggestions on how to clean it.
Yes starter turns and engine turns but engine does not fire up.
Confused about wires.
- Black and white wire by coil is a faded black and yellow wire.
- Black and yellow faded (white) with red heat shrink goes on coils plus and needs 12 volts
---- Where does this wire come from. It does not get 12 volts. Is it not grounded somewhere.
- I have 2 other black and yellow wires one going to metal box on top of coil and one from metal box to coils plus side.
- One black wire from harness with black heat shrink going to negative.
- Is that how it should be set up.
-I thought that metal box was the ballast resister. What does it look like.
From the wiring harness by the fender there is 2 Black Yellow wires. The thicker wire should be 12+ volts, verify this while cranking. The other smaller Black Yellow wire is a bypass wire to supply coil with 12+ volts at cranking. Connect the larger Black Yellow wire to on side of the Ballast Resister( that's the box on top of your coil) Run a wire from the other side of the resister to coil+. This will power the coil. Take the smaller Black Yellow wire and connect it to coil+ as well. Coil+ should have 2 wires on it.
Now we know you have power to the coil. Next step is the dizzy. How many wires come out of that dizzy you have 1 or 2?
I can't believe its been 5 years and not a lot of progress on my Fj40. Soon after the initial post I was able to talk to the previous owner and he showed me how he was able to run the Fj40. I'm not sure what he did but it looks like he bypassed the ignition switch by connecting the ignition coil straight to the battery. Once this wire is hot the cruiser will start. And once the wire is cold the cruiser will turn off. The key still starts the engine but with out the wire being hot it just cranks over. So, my thinking is that the ignition switch is bad? Checking to make sure I have diagnosed it correctly before going down a rabbit hole. The original owner also told me that he had to change the engine so I'm not sure if he pieced parts together to make it work.
1. Picture if my sketch of what I think is going on.
2. Picture of Top of Ignition Coil and Battery
---Purple circle has the Black wire that needs to be hot to crank over the engine
3. Picture of Black/White wire not hooked up
4. Picture of Front of Ignition Coil
5. Picture of Starter. It looks like the Black/Yellow wire was soldered on.
