I've got this 75 FJ40 (2/75) and I can't get it started. If I jump the + end of the coil to the battery post it fires right up and keeps running until I remove the jumper wire. When key is in the ON position, I have current to coil.
This is what I've done/checked so far:
1. new ignition lock
2. new ignition wires
3. checked fuses and wires between fuse panel and coil
4. checked for clean, solid ground wires
5. checked for clean, solid battery posts and starter post
Any suggestions will be helpful and appreciated. I'll be eagerly awaiting replys from those of you who know about eletrical type of stuff. I'm more mechanical...if it moves, I can fix it. Until then, I guess I'll go check the tire pressure and see if that helps
