Electrical losing grounds
Los Angeles, California
Website
forum.ih8mud.com
1983 HC 47 not sure if this is the correct place to post this. Since i got back from the wash board roads of Alaska i been losing ground i.e, running lights, head lights. Just lost power going to my air conditioning compressor. My question; is there one ground wire that is part of the wiring harness? On the head light and running light i just simply grounded them to the Chassi no problem. There is power at the switch but no power at the compressor. Not sure where to put the ground in this situation. Thx
Dis regard the yellow, wire power is coming from the black and white wire.
Lost Marbles posted an electrical schematic in this thread. Real time help
On a 40 the headlights ground through the harness and the markers use the old school type ground directly to the body.
If all your lights ground through the harness you should have a hot wire and White/Black stripe ground wires. The harness will probably have WB ground to the frame somewhere and the voltage regulator.
I would start by cleaning the battery ground cable. Might not hurt to post up some pictures of how you’re grounded.
Thx. My question is about losing ground to the power that goes to the air condition compressor. There is power at the switch but not to the compressor. Somehow power is lost between the switch and the compressor. Thx
Check your binary switch, if it has it. If you don't have enough pressure the system will not power the compressor
thx, there is no power to the wire connected to the compressor. when i take a powered wire and connect it directly to the compressor, the compressor turn on. i am losing power between the compressor switch and the compressor, thx
