electrical issues. help please!
St Anthony, ID
i recently obtained a 40 that supposedly had it's electrical system upgraded to a 24v fuse box. well, i burned an alternator and after about 30 seconds of running the replacement, it burned and started to smoke as well. what would cause this to happen and what can i do to remedy the issue? the system is a 350 swap, carb'd. thanks.
What is the voltage at the B+ lug of the alternator (with the engine off)? 24V would be unusual and may account for your alternators burning out. Some diesel versions (BJ) may run off 24V, but I have never seen a gasoline FJ with a 24 V system.
so what is it that determines the voltage? would using a 24v fuse block on a 12v system convert it to letting 24v get through? ugh-i need to learn about electricity.
This is voltage across the batteries, but it is measured at a point that is less ambiguous that just saying the battery voltage if you have more than 1 battery. 24V fuse block is a vague term as there is no such distinction. The fuse block doesn't care what voltage is applied.
i guess i don't get it then. what is it that makes it 12v or 24v? is it the resistance in the guage of the wire?
i only have one battery. i can measure it as well. i'm just trying to make sense of it. i'll report back after i measure it.
voltage on the battery terminals and at the alternator is 11 with the cruiser off. i'll have to jump it and check it when running.
I think you can safely conclude that you have a 12V system, with a somewhat discharged battery. To be honest, I can't imagine any way you could burn out two alternators (1 in 30 seconds), even if you had a dead short across it. If the alternator output was shorted, the battery would be long gone and read 0 V. I would replace the alternator if it had a warranty as it might have been bad and if it keeps eating alternators, take it to an auto electric specialist.
cool-thanks. i haven't tested the other alt yet. maybe it just had some grease or something that was burning inside it causing it to smoke. i just assumed it burned it. however, the po told me he went through 2 alts and i have only driven it a couple of times and burned the one the po put in it the day before he sold it to me. so, maybe a visit to the electrical specialist is in store. thanks for your responses pin! i appreciate it and feel extremely dense with anything electrical.
what is the volt when running
right, if you have 11 withthe cruiser off, jump it or what ever to get it running, get the rpms to arou 2000, volt if working will read between 13-15. if still at 11, dead alt.
If you put a battery charger on your battery and the meter on the charger jumps from charged, to not charged, good chance your batter has droped a cell(dead battery).
Did the smoke smell like electrical smoke, or greas smoke. I used to have VWs as a kid, I know electrical smoke smell.
it was electrical smelling. i'm going to take the alt in to have it tested today. another thing that made me think it burned the alt is that the voltimeter inside the cab read 14 for a little bit, then dropped to 11. so it seems that the alt quit working. i guess we'll see. i'll post when i find out just what is going on.
