I thought my starter went out so I got a new used one. But that was not the problem. I stuck in the new one this morning and still nothing.
I fiddled with some wires (those behind the ignition and then where those wires connected to the selenoid and a ground on the firewall. I went in and it cranked over a few times until i let off. I tried cranking again and then nothing. No voltage at all. No clicks no nothing.
I then tried to charge the battery and my charger said it was only putting out 8 volts and it would not allow it to take a charge. So I tried to charge it jumping it from my running car next to it and then it would only read 1.7 volts. And it was taking a huge draw on the other car and the wires were getting hot on the jumper.
So I pulled the battery out and the second I took the hot off the starter engaged and my rig started rolling backwards as the starter was cranking it along. I finally got the + terminal all the way off and it of course stopped. I went to see if the battery was ok and it put out a good 12.4 volts and was topped off.
I put it back in and no matter what I did I could not get it to crank over or even get any power to the dash or selenoid.
What is the deal here and why would it engage when taking the battery terminal off. I have a good tight connection all other times?
