Electrical Idiot needs help
Nashville Tn
A lot going against me as a newbie. Hope ya'll can help. I have read so many threads I have confused myself. My plan is to install an amp and run my ipod directly to it through a volume control/charger.
1) If I install a separate fuse box, must I still run my accessory applications both to the ignition and fuse box?
2) If I do not add a separate fuse box, must I run the accessories to both the ignition and battery (both + and -) with an inline fuse?
wiring
you can wire it into a circuit on the fuse box that is live with ignition on or just run a wire with an in-line fuse in it directly to battery.
I would still use a separate in-line fuse for your amp
just depends on if you want it to shut off with the ignition key or dont mind turning it off when you get out of the vehicle
the ground can be made straight to the frame with a terminal end just be sure to connect the terminal to clean metal on the body
