Electrical help
Adventure Teq
Liberty Utah
Website
www.instagram.com
Hey folks,
I have been hammering out a few different elec probs which I will spare the details til later if needed.
The problem: Headlights are not as bright as they used to be and seem get even more dim over a short period of time of driving (10 min or so). They will continue to dim if I turn on all the fans and wipers etc... And while driving in the day the ammeter will stay about middle but with headlights on it goes down to about 1/4, then any little thing like brake lights, signal, fan or anything will bring it all the way to -30.
Brand new battery, got alternator at least charging system now (nother story).
Batt test results:
14.65V just sitting
16.72V first start up
16.69V park lights on
16.67V headlights on
16.65V everything on
OK so I've deemed that the alt is charging the system adequately.
Qestions: Is 16 V too much and need I be concerned bout that? What the hell is the purpose of the ammeter and how does it detect whatever it's detecting being that I have an interally regulated delco alternator (SBC)? And is the ammeter supposed to stay in the middle no matter what the load is placed upon it?
Basically, why are the lights dimming with plenty of power at the batt?
Ugh, thanks for bearing with me. I hate electrics.
My bet is that your alternator is hooked directly to your battery, bypassing the ammeter, but the headlights and other Toyota accessories are drawing through the ammeter, thus the negative readings.
Your alternator puts out too much current to safely run it through the ammeter.
I would question your voltmeter, no 12v automotive battery, unless defective? is going to read more than ~12.5 volts sitting. You should be getting no more than ~14v when the rig is running.
In fact you're right and that all makes sense now. But I'm still clueless about why the lights dim.
Cheap meter possibly, but still it's all relative giving same readings.
Where's the disconnect between the batt having plenty o juice and all of the electrical components not getting what they need from it? All terminals are squeaky clean and all components look to be ok, just not sure what to test next. I guess see how much each component is getting down the line through the fuse panel to the component. BRB
Thanks! :beer:
Relatively, the differences between "engine on" and "engine off" to be about right, regardless of the accuracy of the numbers.
What about grounding? Do you have good body-frame-engine groundstraps with clean connections?
Hawk--If you are running with stock wiring, what 66fj40x2 and CruisinGA says may be part of your problem. Go to www.madelectrical.com and click on "electrical tech" and scroll down to "Brighter Headlights", click on that and read it.After reading that one, read some of the others that deal with amp guages and charging systems. It will probably be a real eye opener on wiring for you,it sure was for me. The same websight has loads of more info on alts, starters, and other wiring that I am finding real informative, and causing me to add to my "to do" list. Hope this is helpful.
66fj40x2 said:
I'd bet if you the lights off relay instead of the OEM harness they would be brighter and not drawer the ammeter. Mine did the same thing after I went to a GM single wire alternator.
Hmmm. Could try it. But the problem is that it's not just the lights, the more things I turn on the more they all slow down (wipers, fans)
I've got a good 12 V at the headlights all the time regardless of what other comps are on or not (engine running). I checked all of the hot sides of the fuse panel and all have above 12 while running.
I just checked all the grounds recently and I cleaned a few up and the others seemed fine. I think I better check em out more thoroughly tomorrow. I mean it could be each individual component's ground is bad, but why all of them and why not any other probs, and why do they individually run fine.
Did I mention I hate electrical, thanks fellas. :beer: :beer:
Handcannon, that was very useful. I had checked in at that site before, but that healight section explained a lot. I'll get to workin on that stuff and see what comes.
The thing that gets me is that it ran fine like it was for quite a while, then one fog light went out, then an elec rad fan. I isolated and eliminated those problems and now the rest of the factory components are acting this way.
Thanks everyone, I'll post up later.
Happy Thanksgiving! :beer:
Could it be that your alternators voltage regulator is not set properlly, and you are actually getting 16V, if this is the case you would likely start blowing other components of your electrical system.
I had a very similar problem. Replaced the regulator and had some success. My wiring is far from stock which is also contributing to my electrical problems, but the regulator should help you out a lot.
