'64 FJ40
front lights all work fine
rear license plate light works fine
brake lights work fine
however... no tail-lights (running lights) and rear turn signals both blink about half power regardless of which light should be on...
ok so you take out one of the rear bulbs other turn signal works fine... but never any running lights and they are on the same power line as the license plate light...
grounds are all good... metered them...
any ideas???
it the brake lights are working off the top filament of the bulb... i assume the running lights should be running on the bottom filament...
any suggestions w/b helpful... two of us spent 4 hours with a meter testing this and that and they should work... but put that second buld in and nothing.... makes no sense!!
thanks!
casey
'64 FJ40, '83 FJ60, '97 Tacoma
any ideas???
thanks!
casey
