Electrical GURU ?s
Buffalo, Wyoming
I am insalling a voltmeter, tach, and vacuum guage.
1. Where would I find the 12V terminal on the ignition switch for the volt meter?
2. Where would I find the dash lighting circuit to tie all the guage lights into?
3. Do I need to install inline fuses? If so how many amps?
Thanks!
Simple matter of running these circuits down with a test light, energize circuit, poke wire, if it lights, that's it. Or, you can look in the tech section here or fsm for wiring diagrams. All aftermarket circuits should be fused imo. Fuse should probably be around 15 amp.
I agree it should be fused, but I think 15A is a little high for a gauge/light. There should be a power rating in the instructions of each gauge. I would think that 2A should be fine for the lights in them - they are pretty small lights. As for the gauge power itelf I am not so sure, but pretty sure that 15A is a bit on the high side.
All of those things use so little power that you can just run them off of an existing fused circuit that is hot with the key on. Obviously the lights should run off of the running lights circuit. You can find the color codes for all of that wiring in the factory schematic.
Fuses protect wires, not components.
General reference below... Not true in all situations.
18 gage - 10A
16 gage - 15A
14 gage - 25A
12 gage - 40A
If in doubt, go high on the gage size and low on the fuse.
Ffor your meters: 18 gage because it's easy to find and use 5A fuse to protect the feed for all branches.
I'd connect the power for the gages to the ACSY circuit. I don't recommend tapping off the key switch, as that's a large gage wire and you don't want to compromise it. You can tap off the instrument cluster for ACSY, lights, and GND to keep the wiring together (but you can get these circuits in lots of other places if you want to).
The 1976 wiring diagram in the Tech Section should be accurate enough for your task.
ACSY: Light blue / Red
Backlight (parking lights): Green
Gnd: Wht / Blk
Good Luck!
Howdy,
The information and color coded I will be using are coming from a wiring diagram for a 1979 FJ40. I have a 1976 model and the colors seem to match up so they may as well with yours. I would recommend testing a circuit before tieing in to it. Here we go. Your ignition switch receives power from the battery through a white/light blue wire. The accessory position is Light blue/red, and the ignition is Black/yellow. Regarding the internal lighting: If you want these gauge lights to dim with the dash lights then the Red/Black wire on the light switch is your choice. Full bright only from the Green wire on the light switch. If you splice into either one of these with 16AWG wire, no fuse should be necessary as the bulbs would blow before the current draw exceeded the wires capicity. This circuit is already protected by your 15A Tail light fuse.
The accessory position of the ignition switch feeds the lighter and radio fuses. I would splice into one of these for the voltmeter. Preferably on the output side of the existing fuse. A voltmeter draws minimal current so no fuse is necessary provided you use 16AWG or 14AWG wire. I presume the vacuum gauge is mechanical needing only the light listed above. As for the tachometer, aside from the light the ones I'm familiar with would need only a ground and ignition pickup. Your installation instructions should guide you there. I hope this helps.
Leon...
You guys are great:eek: This is why I love the MUD! I thank you very much. This should make thing alot easier. I am very mechanical but am lacking in electrical knowledge. Something I should study more. Leon, even I can understand it with what you wrote! Thanks again!
Erik
One easy place to grab power for the gauge lights is off the light that's built into the upper dash pad for the dash switches or the lower that's (supposed to be) above the heater controls on the floor.
Ok, boys! Here is the product of your instruction:cheers: Thanks again:D
Good idea
I never considered putting gauges in the radio opening. Considering you pretty much can't hear it while driving anyway that's a good idea.
Leon...
I thought it would be a perfect spot. What good are gaugrs if you cant see them. I figure I might put a radio in the center console I made out fo an ammo can. Thanks for the help:cheers:
Erik
