Electrical guidance please.
Southern California
Looking to add a blue sea twin power port on my center console in one of the coin trays. Where is the best location to connect the power and ground wires. I can run the power all the way to the battery but looking for suggestions.
One way is to use a Bussman Add a Fuse that taps into the fuse box for power and then ground it to any screw/bolt into the sheet metal under the console. That's what I did for some low amp lights. Or you could go to the battery and then ground locally as above.
I'm thinking of adding a pair of buss bars somewhere near the dash so I can add future electrics without reinventing the wheel each time.
Oh yeah, the cigarette lighter circuit is a good source of power.
I have a double usb to cig outlet in mine so it shouldnt be a problem. The only negative thing for me is that it is only powered with the key at least in the acc position. I will be adding an additional one that is always hot. I cant charge while away from the truck.
Its super easy to run a wire all the way to the battery through the grommet in the firewall.. A basic setup would be a single fuse at the battery, run the hot to the usb port and find a conveient ground on the body.
I love your name picture. I have a pig tattooed on my left arm. Thanks for the advice.
I'd make the USB charger always hot so either find a constant hot fuse in the dash or go all the way to the batt.
Thanks for the help all of you gave. I ran power from the battery and put the USB port in the center console. There was a factory ground point right under the console so it worked out to be pretty straight forward. Here is a picture of the final set up.
