electrical gremlins
atlanta
Got the engine back together after two years but I can't get any fire to the starter and have few other weird elctrical symptons.
Blinkers and heater blower work without key in the ignition (this seem strange).
No voltage at fuse panel, coil or alternator.
Good Voltage at battery. Ground from battery to frame is good and I also have the ground strap from the starter bolt to the frame.
Starter works if I jump 12v to the male blade fitting.
I have checked all the fuses and all look good but I have not been able to locate a fusible link. This is on a 4/79 FJ40. I have been fusing around with this for 1.5 days and am quite frustrated.
Alf
Do you have stock wiring or did someone "customize" it?
Stop lights, head lights and hazards should work w/o the ignition switch, but the heater should only work with the ignition switch on?
Without the strange symptom of the heater blower running, I would suspect a bad ignition switch or the circuit leading to it.
In the absence of a more detailed description of the problem, the general electrical trouble shooting guide is:
Always check for a bad ground first, because it is easy to do and is a common problem. Run a separate ground wire from the device ground to the battery - post. This will immediately illuminate a bad ground.
Don't confuse voltage with power. Power is volts times amps. If you have a high resistance (bad) connection between the device and your voltmeter, you can measure a full 12V and yet you can have little power because not enough amps are flowing.
To trouble shoot bad connections now that you know that your ground is good, start at the non-functioning device with its switch on and measure voltage. The voltage will be low or if it is not, it means that you are still measuring upstream of the bad connection. If you have 12 V at the bulb and a good ground a good bulb will be lit.
Keep working upstream in the circuit until you find the point where the voltage jumps up to 12 V. Now you know that the bad connection is somewhere between the two measuring points. Understanding schematic diagrams helps, because it shows you what point to measure next in the circuit and it tells you what component it is.
Then you just dig in and find it, or run a new wire between point A and B if you don't want to dig too hard.
3 hours later and the problem has been solved. Here is how it went down.
No voltage and no continuity to the BW wire going to starter. However there was voltage at the ignition switch. I couldn't get to the main harness connectors ion the cab side of the firewall mmediatley as they were tucked very nicely behind my factory AC unit on the passenger side. So I pulled the AC Unit, and the heater duct work. Fortunately I had yet to add freon to the AC system so this was not to bad.
Found the plastic wiring joint that contained the BW wired and seperated it. No continuity from the ignition to the upstream side fo the plug but had continuity from the down side stream side of the plug to the starter spade connection. So keep working up stream. Pulled all the dash switches so taht I could get at the entire harness (this is a bitch) Scratched my head as to what to do next as that is one massive gang of tape with a sh*t load of wires. Went back and tested more continuity and found some other irregulatrities as I could only get continuty on the BY wire and not the other three including the aforementioned BW. Then realized that the wires on the plug I am testing are a smaller gauge than on the iginition end this doesn't seem right. Looked at all the other connectors dangling around and found a seperate four wire snap connection that had all the correct colors but had previously been snapped to a different set of wires that were staying inside the cab.
Long story short I had snapped together the wrong connectors. Usually this does not happen as Toyota makes the snap fitting unique especially in close proximity situations. I check for continuity on my new found plug and all was good. Snapped the correct ones together and the starter cranked, heater blower and blinkers no longer worked with key in "off".
Went and told the wife who gave me that ever so pleasurable reassuring smile, like I knew you would figure it out.
Stupid mistake but happy ending.
Now I gotta figure out why I am not getting fuel into the carb. Engine runs when I put gas down the carb but cuts out when this goes dry. Carb bowl is dry. New mech fuel pump. I put 5 gallons of fresh gas in the tank that had been dry for two years. I am going to hook up an electric pump tonight just before the mechanical pump and see if I can get fuel to flow as I may have a blockage in the tank or in the lines.
ALF
