Electric Vacuum Pump
Kelowna, BC
I looked into an electric vacuum pump, found about 3-4 people and the general consensus was that they seemed to work for a couple
of years, and then started to have problems. This one also has a min temp of -25C, which could be a problem in Canada ( outside of Van., of
course!) But worth a look for sure.
Yeah I got rid of everything that required a vacuum pump and got a 70amp 24v alternator for my truck great mod. For me only had to enlarge the hole in the bracket 20 minut install got rid of voltage regulator and a couple of other things and a s*** load of wiring.
I used one of these on the BJ, worked flawlessly. They are designed for constant duty and I am sure many, many years of service, like a Swiss watch. They use these as the primary vacuum pump on electric cars and need to meet European safety standards. I still have one kicking around
http://www.metricmind.com/products/706e2/
Not sure how new but they are very common. Running one on the L engine and it seems to be good. Lots of guys have started converting to them (diesel section). not sure if they are available in 24V but worth a closer look. Hell, you can buy 3 of them and still be cheaper than Toyota's one.
http://www.ebay.com/itm/NEW-ALTERNA...Parts_Accessories&hash=item1e6d49d122&vxp=mtr
Rare Electrical is a very good source of 24V alternators and starters. Here is one for my Safari which is a fraction of the price of just the OEM vacuum pump. http://www.rareelectrical.com/p-169...-patrol-lr235-402-23100-c8604-23100c8604.aspx
on a note regarding 24 volt alternators, the only real difference is the voltage regulator. you can typicaly just change it and convert your 12v unit to 24v. you will also get the same current so say twice the power.
