Electric Problems Continued
Garner, NC
Ok, so I've been plagued with an electrical problem that I have not had 100% of my time to dedicate to, I'm sure nobody else here has that problem!
Problem: No turn signals, no running lights, no dash lights. (All are on same circuit)
What I thought the solution was: PO hacked the wires, put different tail lights on, got rid of the rear side markers. I put new OEM tails on (brake, reverse, hazards work), and was going to put the rear sides on, hoping that would finish the circuit...
What throws a kink in my theory: Took it up to the store after a little rain... running lights work, interiors work but still no turn signals...
Is it possible that some moisture is helping ground that circuit? Where would I start my tracing?
Start at the fuse block, since all the lights on the same fuse don't work. It is not likely a ground problem as the lights have separate grounds.
Check the fuse, clean the contacts and if that ain't it, move to the switch and repeat.
Or: Turn all the lights on and start checking contacts and connections with a volt meter. When you follow the circuit and find that the voltage drops to near zero, there is a bad contact up stream of where you measured.
