Ehsan's Soft Top Installation HELP - PICS
I purchased this top years ago and FINALLY have decided to put it on. I typically let the cruiser "rest" in the garage during the winter and leave the hard top off. I decided to test fit the top prior to painting and have run into some obstacles!
I have searched and read a bunch on this. Everything appears to be fit right. The problem I am encountering is the top appears to be too short from front to rear. I started in the front and stretched towards the back, but the rear seam is about 3-4" from clearing the last bow. I measure the height of the rear bow and it is approximately 38.5" from the tub. I read that it is supposed to be 1200mm or (47.25"). This would mean that I am off by 1.25" but I cant imagine that this will make the difference in almost 4" of what I need to stretch back. Also, I adjusted all the points to make the cage as small as possible.
Any help would be greatly appreciated. I have been scratching my head all weekend and am hoping that the pics and some detective work will turn up an answer.
Thanks,
Joe
Install your footman loops and attach as tightly as it will fit and then slowly try to stretch the fabric back. Mine looked like yours when I first put it on but I was slowly able to stretch it to fit. Start at the front and work your way back. I have my hard top on for the winter so I cant take any measurements for you. Good look and nice looking rig.
Good advise My top fit the same after sitting is a hot Las Vegas garage for two summers the back door velcro flap will help if you can get ahold of It pull down from the inside and go around the cross bar and catch at-least some of the velcro I also hung some weight on mine and let It sit over night It will stretch just do not force It.
good Luck
I had to elongate the holes in the cross bars then put a strap around to compress the top, tighted the bolts, I also had to remove 3/4 of an inch from the rear bar at the bottom, it still fit tight, Larry
DO NOT PULL too hard. I have ripped a strap off trying to stretch the top to fit. Get the top nice and warm before you install it. One thing that worked for me is once you can get the straps into the footman loops is to make a hole in the first 1/2" of the strap and let it sit and get used to being stretched. Come back and tighten down the straps a little more. Then keep going until it is where you want it. It also helps to work the canvas over the rear bow with your palms until you see some slack in the straps.
Also, from your pics, there's no way you're off by a foot. Are you measuring from the floor up to the bow?
It is off by 1.25 inches based upon a 1200 mm measurment I read somewhere. This is the rear bow measured from the top of bow to the floor of the tub. Is 1200 mm correct? Also...if I take the top off next summer, am I going to have to "re-stretch" the canvas? Any other ideas on what it could be? Is there somewhere to get measurements on the top from front to rear?
Thanks for the help!
since you have the hard top and that top has just been sitting around and not really working out you could always donate it to a needy college student :beer:
DO NOT PULL too hard. ... Get the top nice and warm before you install it.
This is great advice. If you can do the install in the sun on a warm (or hot) day the top becomes much more pliable than when it is cold. Also, I found that I did not have the rear inside/velcro flap routed around the bars correctly - this added bulk to the rear top bar and made if more difficult to stretch it out far enough.
Thanks for all of the thoughts/advice! Is there anyone who can confirm the 1200 mm height of the rear bows. I am thinking to cut them down to "spec" if that is correct. Then I will proceed with stretching.
Thanks!
Joe
Thanks!
Joe
1,200mm is correct.
i wouldn't cut anything
mine looked like that too... the second time i installed it - everyone there was freaking out... 15 min later by light tugging and rolling our hands over the fabric it fit perfectly
How much hardware should come with my Ehsan Soft Top?
Bolts
Washers
Nuts
etc.
Nuts, bolts, washers, 4 rear mounting brackets, footman loops, eyelets for twistlocks. Why, whatcha missing?
