Hello,
I have a 1994 FZJ80 with the original 1FZ-FE. It has 120k and was brought home from SoCal about a year ago. Anyways, I have been fighting an EGT sensor-related CEL for that entire time and I *think* the issue is a bad sensor based on my ohmmeter investigation. Since a new EGT sensor is prohibitively expensive, I have sourced a used sensor from a known good system.
The issue:
My current sensor uses a 4P connector with two open ports (two wires) and the sensor I received uses a 2P connector. The sensor itself has the same appearance and threads. Are the sensors themselves interchangeable? I can easily depin and swap connectors but I'm not sure if the sensor itself is actually the same or not.
Any insight would be appreciated.
Thanks!
Sam
The issue:
Thanks!
Sam
