EGR valve
San Diego, CA
Just barely passed CA emissions with my 91 Cruiser, and was told by the test only site I need a new EGR valve. Any ideas on where to get one?
You can get one at any Toyota dealer; if you want a discount contact CruiserDan at American Toyota.
Howdy! EGR valves primary effect is on NOX. You may have a bad vacuum supply/leaky hose, bad/leaky diaphram so the valve doesn't open, or a plugged EGR passage in the manifold or the base of the valve. The first and last problems are cheap and easy to fix. The second requires replacement of the valve. All three can cause a smog failure. John
thanks for the info
