I am trying to change my EGR valve and I need to remove the EGR pipe nut. Does anyone know what size wrench I need? I am assuming I need an open ended wrench due to the lack of space back there.
I have no idea what code 71 means so I am no help there.
Code 71 is basically the same as our OBD-II P0401. It might be a combination of 401 and 402.
For the large EGR nut, try using the crescent if you have one that will open that wide that isn't too large. I had to use a "Robo-grip" type tool that I got from Sears. It is like a set of wide-mouth pliars that has a slider that lets you open it real wide, then it clamps down when you squeeze the handle.
I'll try to find a pic...
-B-
