I'm not sure. I deleted my EGR and VSV which eliminated all of those plugs. I believe one went to the air pump. I'd have to look at mine to be certain. Take a pic facing the other direction (180 degrees). Like from the Driver's fender pointing to the engine.
It appears that your EGR system is still there. Well, I am assuming it is since your air pump is still there. They may have done the "BB method". Are your vacuum lines disconnected going to your EGR pump?
Here's what it looks like when you delete your EGR, VSV, air pump, etc. Notice how much of your stuff is missing from my engine bay. You will see my three plugs just laying there. I can't remember what they go to specifically. I just know they all got unplugged when I removed my EGR, VSV, air pump, etc. Maybe @jonheld can chime in. He will know off the top of his head and probably have a beautiful diagram handy that shows what plug goes to what. He knows his $hit!
edit: The three plugs go to the vacuum lines of the EGR and VSV system I believe...Follow the vacuum lines and see where they go.
Hmm.
Many thanks. I'll have to trace these all tomorrow. I kinda figured from some EGR/VSV deletion stuff I was looking at that the broken plug was due to some graceful attempt at deleting... something.
I really like how the engine bay looks without all the air stuff. Did you notice any engine behaviour/MPG change after pulling it out?
Yes. My only regret is not doing it years ago. My gas mileage has increased. I am now 5 tanks through and am seeing 12.1 as my lowest MPG on a tank. Averaging 12.3 MPG over the past 5 tanks. And no, that isn't related to "summer gas" vs "winter gas". I run 87 octane with 10% ethanol. Prior to the EGR delete I had done a tune up of new plugs, wires, distributor cap, PCV, and installed new O2 sensors. I also noticed that my 80 was "quicker" and more responsive. No, it's not a race car but it definitely feels "better". And yes, it idles better now too. I'm going to advance my timing a little bit as well and see how much improvement I get from that.
These are just added benefits for me doing it. I deleted it all because I want to add a dual battery setup and getting rid of this stuff makes it cleaner. I also would like to eventually add a York compressor which would go in place of where the air pump was.
I highly recommend going to this link and following the tune up guide by @jonheld. He is THE 3FE guru. Do as he suggests for your 3FE.
One other note, when doing a tune up buy Toyota OEM parts. Contact @cruiserdan or @beno. They will get you what you need at a fair price. They support the MUD community and know our rigs better than anyone.
