Egr delete questions
Wherever the money is!
Not trying to beat a dead horse here but I've been doing a lot of searching for some actual instructions as to what all I can get rid of for the egr and haven't had much luck. I'm not a mechanic by any means and am still fairly new to owning my 80 so any help would be appreciated.
It looks like you have a '94, right? Would be helpful if you added that to your signature.
For my '93 I am going to follow the "redneck" version here as the quick, reversible fix: https://forum.ih8mud.com/threads/94-code-71-egr-bypass-and-redneck-technique.332126/
Assuming you have a '94 (pre-OBD2) you may not have to use a resistor, only a jumper, on the ECM side to keep the code cleared. If the jumper doesn't work, you probably need to add a resistor. I haven't seen a definitive resistor to get but most look like they are using between 1K-ohm and 5K-ohm. (https://forum.ih8mud.com/threads/disable-the-egr-system-the-mostly-toyota-way.308200/page-6) If you have an OBD2 version or can't get your codes to clear check the EGR Readiness thread here: https://forum.ih8mud.com/threads/egr-readiness-achieved-with-egr-removed.437888/
Once I verify that the EGR bypass is working and there are no codes I may make a couple blank-off plates (https://forum.ih8mud.com/threads/how-to-make-an-egr-block-off-plate.277545/), get some vacuum plugs, and then remove the system entirely. Or I may just leave it until I need the space or have another reason to be monkeying around in that area.
There are a bunch more threads on this but these are the ones that seemed the most useful to me (prior to going through this) so hopefully they get you going in the right direction.
Thanks for the help, hoping to get this done soon. I do have a 94 and like most others, I just want to get rid of unneeded stuff. I don't plan on ever selling my 80 so no worries there and I've seen most other members say their rig runs a bit better if anything after doing this.
