Bought my 1991 landcruiser about a month ago. Been driving it everywhere. Rough idle, but never stalled. Drove it to get fuel for my tractor Sunday and had to call my wife to tow me about 4 miles home. Just died driving down the road. I started surfing the web and ended up here, so I joined.
Replaced EFI relay. Crank but no start. Jumped B+ to FP. No start. Jumped actual hot post of battery to FP. Starts and runs, but rough. B+ has like .5 volts. Replaced circuit opening relay. No difference. Ohmed out VAF, showed 280, so I sprayed it with cleaner and verified door was moving freely but with spring tension.
I pulled the EFI relay and only had 9.5 volts on the terminal closest to the engine and windshield corner. Pulled fuse panel to see what it looked like underneath and found discolored, brittle wire. I'm going to replace it shortly with 10 ga wire. All the others look intact and do not feel brittle.
Any other ideas?
By the way, no CEL and I assume bulb is out or removed. I don't even see where it is supposed to be. If someone can show me, I'll replace that bulb too. Landcruiser has a OME lift, ARB air lockers front and rear, wilderness roof rack, and bumper with 8k warn winch. Under the hood is bone stock.
Any other ideas?
