EFI question
I have a question for you EFI gurus. I have a 350 in my 40. Has the Howell (early 1990's GM) TBI set up. Computer just stopped working the other day while driving. Fuses all ok. Power is going to the unit, but no output (check engine light, fuel pump, etc.) from the ECM. I swapped out the ECM a spare I carry and it started right up. I let it idle for a bit( < 5-6 min, it did not get hot). I turned it off. Again started right up, no check engine light came on. I backed into the driveway and on the way in it died. Same problem: NO output from the ECM. Fuses OK. I can't even get an error code w/ no power from the unit. Any thoughts on what appears to be frying my ECM? :confused:
Anytime, I have an electrical problem I always check my grounds.
I had a Bronco II, fuel pumps stopped working intermittently, turned out there was a separate ground for the fuel pumps off the computer main connector and that socket was loose. Slathered some of that dialectric grease on the connector and never had that problem again. (Owned the car 4 more years)
Check for a short circuit (probably intermittent) on one of the output lines. Are you sure it it fried? My understanding is that they have overload protection on the outputs.
Also check for over voltage. Electronics do not like voltage spikes.
It fired and ran for few minutes, really until I began to move the truck. I think I favor a loose ground. I would think a shor would blow a fuse and they are all ok, both at the main block and the ECM block. I did a quick check last night and did not see anything. Tomorrow I will spend whatever time it takes.
