Effin new guy
Atlanta
Hello all, I might be a regular here real soon. I just came across a 1993 with roughly 230k on the clock, has a small amount of damage on the rear quarter. Also has an electrical problem.
" Two front windows motors do not work. The car has shorted out twice while driving. While in gear the engine stays on but touching the accelerator does nothing. All check engine lights come on and power steering goes out. Turning the car off and then back on fixed it."
It's probably a cheap fix and just a lot of hours searching through to see what the problem is, just wondering if anyone has experienced such a thing. Any help would be greatly appreciated, thank you.
that seems high for body damage and electrical problems...
Son of the original owner, haven't seen it in person. I wasn't planning on paying asking price. I was just looking for some input as to what the problem might be.
As someone who nearly got plowed by a semi when my car shorted on the interstate and then later caught on fire while I was driving, I never recommend buying a vehicle with a "cheap fix" electrical problem. If it were a cheap fix, wouldn't it be done already? I'd look for something without that issue, regardless of how nice it looks...
If the "power steering goes out" but the "engine stays on" then one of the statements is false. As long as the engine is turning, the power steering will work. Anyone that refers to it as a car, and describes the status of it as on/off doesn't know what they are talking about enough to describe symptoms properly. They just don't know the terms to use, what observations to make or how to make them. You need to see it in person and make your own observations. Possible issues include but are not limited to:
  • Loose battery connection / bad battery wiring
  • Loose alternator connection(s) and/or bad alternator wiring
  • Fusible link issue
  • Bad battery
  • ECU wiring issue/eminent failure
  • Melted harness and/or short somewhere (anywhere) on the truck
  • Loose ground(s)
  • Power window issue may or may not be related
The list of possibilities is quite long.
gentlemen, we can rebuild it, we have the capability of building the worlds first bionic Land Cruiser...
Thank you Sbman. The no power steering while the engine was running made no sense to me either and is what made me start this thread, I didn't know if you landcruiser boys might know something I didn't.
I doubt the problem will repeat itself in the 20 minutes I'm looking it over so I was hoping for it to be a common problem that you guys were aware of.
It's probably the ecu or wiring harness as I doesn't sound like he completely lost power, I'm guessing the blower motor and radio were working which is why he thought the engine was still running.
Anyway it's probably a headache. Though I didn't think $2500 was a lot for something I could dump 5-6k into and have a sweet mud truck.
Thanks.
The power steering pump these trucks is gear driven so not even a broken belt will stop it as long as the engine is turning.
From that description I am not even sure it is electrically related. Sounds like it just died suddenly and had to be restarted. How do they know it 'shorted out'? If all the dash lights came on does not sound like a short.
It could be a short at the #6 cylinder area of the main harness from the ecu. It pases by the egr and is a common failure point from melting due to the egr heat, that can cause any number of odd issues and would be one of the first place I would look.
If you haven't read it, go through the slee 80 series newbie guide.
It's a 93, it's probably the Head Gasket... :flipoff2:
Just kidding. Offer the guy $750 and take it off his hands. Worse case scenario you can't figure it out and you have a parts truck. Best case scenario you figure it out and wheel the s*** out of it.
