EDIC AND FUEL CONTROL RELAY PROBLEMS
newcastle
So I’ve wire up the edic and fuel control relay but EDIC motor won’t move. I’ve opened it up cleaned the brushes and stator cleaned out the old grease and put new grease in and it was spinning by hand. I’ve followed the wiring diagram from my original manual plus one I drew up to mark off as I went along. My question is now why won’t it work ? And is it worth getting an auto electrician to look at or to do the dodgy and make a push pull cable up to the cab to shut the engine off. I just need registration to get it on the road !
Below is pictures of the diagram and in the motor and relay
Cheers !
Cheers !
check your ground that comes off the EDIC and grounds to inside of fender
(check the board and all the solders on the other side of the fuel control relay; remove from back of casing
I also noticed the wire crimp missing a wire....
Yep going to add an extra ground from the motor Mount to the Meg terminal on the battery and the relay Mount to the keg terminal on the battery aswell.
Yeah do you know what wire that would be ? 12v+ to the coil ??
EDIC is not the relay
EDIC is the EDIC
there is a ground coming off of the actual EDIC that needs to be grounded or your truck won’t fire
Yep sorry if that didn’t make sense before but edic is grounded I got the motor to spin by shorting the circuit to prove it works and the relay to works with how it’s wired up. So the issues is now the ground from the relay to the edic circuit when it crosses over limits I think
Are the relays picking up? The schematic shows a fuse inside the relay module, is it blown? I would also check the solder connections for the external wires, they can crack and cause problems.
Yep so I had it opened up and seen them clicking over with the key going to on and start position and I got the motor to move by shorting it to the 12V terminal on the battery.
I’m thinking it’s an earth issue maybe my oil pressure switch is buggered causing no ground
