I wired mine in. I’d recommend paying for Injector Dynamics injectors. If you don’t have good data for the injectors everything else in your tune becomes a real pain to get right. Being your first standalone good Injector data will save a bunch of headaches. If your cruiser is auto you will want to wire the haltech as a parallel or piggyback and let the stock ecu run the trans. I cut the engine light wire and have the haltech using the light to show any errors. The wiring will be intimidating at first but you will figure it out with the wiring diagram.
