I have a 1996 land cruiser vx auto 80 series. When it is under 3000rpm the power is significantly poor. Over 3000 and it regains full power. It battles to idle and sometimes hesitates when accelerating. This I have researched seems to be a fuel injection management problem. The oxygen sensor in the exhaust has never been replaced and i'm told a faulty one will cause the symptoms described above. However if I disconnect the oxygen sensor the ECU check doesn't even stay on recognising the sensor has been disconnected. How do i overcome this poor performance and bad fuel econ problem? Do I install a piggy back chip to fine tune the engine or will replacing the oxygen sensor help?
