early windshield frame ??
Hamburg, AR
Would anyone know if the windshield frame from about a 63fj40 would fit a later model? (other than the obvious clamp system stuff) I have located one in good condition and think having the lower vent opening would be "cool". Thanks in advance.
The cowl might have to be cut to fit the defrost tubes or tubes cut to fit the cowl. the width is different at the top of the windshield and wouldn't fit the later hardtop and hard doors. My 65 FJ45LPB has the vent in the bottom of the windshield and the non bug-catcher vent window in the doors. so this one would probaby work (it's not for sale). As far as I can tell the windshield width changed during the 65 model year. the bug-cather were dropped in favor of the later style vent windows and this seems to be when the windshield width changed too. There are two styles of attachment to hold the windshield back my early 63 FJ40 uses the type that bolts the windshield to the cowl while my pickup has the clamp type. Another thing to think about is if yours is a 68 or later the padded dash might be in the way of the bottom vent . I haven't had a windshield folded down on a later style 40 in years but it's seem the dash is a little higher than the cowl. Since the 40s never had the bottom vent and the padded dash at the same time you might want to check this. I sure someone here has done this and would know.
John
Thanks John, that's all great information. I thought the width looked a little off at the top - more square on the early model. The door thing comes as a suprise to me though. I was hoping to use these doors also. I have one of the old (still new) soft half tops with soft doors that I was thinking about trying to run if I can get this deal all worked out. I'll be asking more questions if I can close the deal on this rig in the next day or so. Thanks again!
John is right on, sometime in 65(may have even been 66) the window frame(and doors) changed, you cant use 65 or older doors on a 66 or newer, same with the window frame.
Now that said, I "think" if you have a fj45LPB window frame even from 64, its the same as the latter fj40 window frame..........I "think"
i have a 64 and 65 and the doors bolt on my 72 and 74 wind shield will fit but its not worth the hassle unless you have to have that wind shield wipers are not that good either defrost isnt the same almost be easier to cut the vent into the original but its your choice good luck
they bolt on, but do they fit correct?
Your right they are "cool"
Only special cruisers get them and personally I think they are much better than the cowl vent
