Early model Fuel tank
Phoenix, AZ
Does anyone know if the pickup tube inside the fuel tank on a 1962 FJ40 is somewhat straight or at some point does it turn 90 degrees upward?? I was thinking I might be having dirt or rust plugging it up on occasion. When I have issues I've blown it out with my air compressor and it seems ok for awhile. I was running a stiff wire down it other day and about 12 inches in or so it wouldn't go any further.
If it is like the '73, fitting on the drivers side of the tank, then in goes in straight for a while and then does a curved 90 down toward the bottom with a bevel cut on the end.
Makes sense, I'm probably making it all the way through the pickup tube and just hitting the bottom of the tank.
Doubt the problem is the pickup tube but rather crap in the tank being sucked up.
Yes, that sounds right, especially since I have less than 5 gallons of fuel in there for quite awhile. I suppose it would be better to keep a full tank if it's parked for awhile. And of course treat it with a fuel stabilizer.
Not sure if the amount of fuel will make a difference. Because I live in the desert I drain the fuel from my cruiser that sit. Have a 45 I like to keep running that has the same issue. To solve the problem will need to clean the tank at the least. I have some light weight copper chain I drop inside thru the sending unit opening and rattle around. I can rinse the tank with water on a hot day. With the sending unit out it will dry before it can flash rust.
