Early Ignition switch
Kitsap
Went out to look at replacing my ignition switch. I have the early style ignition with the screw in style wires.
After seeing that, I did a little research because I got a new ignition switch with the 40 that didn’t look like it would work. I now know you have to cut the connectors on the harness and put in spade connectors to slide on the back of the new switch. Easy enough. I have a couple questions.
Would the acc have no wires attached to the new one? My current switch only has 3 wires.
Does anyone know what size spade connectors to use? The wires on the new harness are bigger than the current harness. No clue what size the harness wires are that are in the 40. I would go to the store, but I am trying to not go out unless absolutely necessary!
@ToyotaMatt I looked on your store and saw that you had the connector apart and spare connectors, did you just take the connectors off and reuse them?
Went out to look at replacing my ignition switch. I have the early style ignition with the screw in style wires.View attachment 2256621
My Updated Plug and Play In-Dash Ignition Switch , is easy peezy ..........
- u just match up the wire colors , and use my INCLUDED , 3-M heat shrink Crimp Butt connectors ...........
- u have the older black w / red tracer , that my new updated later White w/ blue tracer
I have added the late Model extra Blue w/ red tracer AUX optional wire too , this, can power any thing in the ACC key position
- my connector simply pushes on ..............PLUG and PLAY :)
Looks premium........until you notice that distracting mustard stain on the cloth :flipoff2:
But! I have no butt connectors.
it seems you may have purchased it before i started adding the yellow big 3-m Butts ?
PM me your shipping address , i can have some shipped out to you right away ...
No Problem !
