Early FJ40 Octane selector
Phoenix, AZ
Curious where others ended up setting the Octane Selector knob on the side of the distributor???
Mine is almost maxed out Advanced, but that could be from my distributor cap being cracked.
The general rule is to set the selector ‘neutral’, half way advanced, then set your baseline timing via the distributor clamp. Then when you need to adjust, you don’t have to mess with the clamp, or a timing light to return to your baseline. Just undo whatever you did in terms of adjustment
