E9 Torx socket for HG replacement ????
Canyon Lake, TX
Im trying to get all the tools ready to do a HG replacement and IdahoDoug says that I will need an E9 torx socket. Problem is that I cannot seem to find one anywhere. All the socket sets I have found skip over E9. Do I really need it, and if so, where did you get yours? Nothing like doing a major car repair in the cold. Good times .... :hillbilly:
Trying to remember why would you need an E9 for. I don't think I have an E9. Yeah there's no E9 in the conventional socket set AFAIK. If you are removing the oil pump cover you can use a 1/4" socket with PH3 philip head. Other than that I can't think of a reason why would you need an E9.
it's for the bolts that hold the EGR valve on. You can get by with a small vise grip.
I bought a set that included the E9. That being said, you could just as easily use the double-nut method, if not more easily. Good luck! Mine blew last January. Good times, good times...
Small vice grip = poor man's socket set. I've got 2 in the toolbox just waiting to be used again. Thanks for the help. :cheers:
