- Joined
- Apr 19, 2006
- Threads
- 33
- Messages
- 155
Hey Guys, I've been wiring up my rear 80series locker in my FJ40. It never worked, even after logic testing the wiring completely. The background of the build is a junkyard 80 series rear with homebrew wiring from reading multiple threads on here.
So I followed a couple threads and decided to take apart the actuator and see if it was a mechanical problem. Here's my findings...
That was after dumping out plenty of powdered rust. I don't know all the terminology of the parts or how to clean them. I am thinking WD-40 with a toothbrush? Then maybe some fine grit sand paper for the 3 pickup points deep in the housing of the first picture. The worm gear in the first picture deep in the housing that connects to the shaft that goes into the switch housing is completely seized. My assumption is that it should spin freely. The teeth on the gears aren't stripped.
How should I go about cleaning everything? How should I go about taking it part more? What parts need to be marked in their position before taking it apart further?
I've been using the following threads as resources, but just looking for a little more detailed help. Small parts intimidate me like a caveman
Resource links...
https://forum.ih8mud.com/80-series-tech/17701-rear-locking-dif-assembly-help.html
https://forum.ih8mud.com/80-series-tech/95649-rear-e-locker-actuator-rebuild-pics.html
Any tips or help you guys can offer? Thanks?
Resource links...
... I didn't have to worry about the worm gear coming out with the whole motor when I popped off the motor case since it was all seized in there. In fact the entire assembly (I think it's called an armature?) is still stuck in the aluminum housing where the gears are. It's not even spinning so I've been soaking that bearing and worm gear with PB blaster. The lower part of the motor has been propped up and have had PB blaster soaking in it for 8 hours now. I just tried to spin the armature (part with all the wires that spins in the case with the magnets in it and it's still seized up. I even tried to put vise grips on the tip of the armature where it rides inside the case (that the 3 screws held down) and the vise grips couldn't break it free. Is there anywhere better to grab this thing and get it to spin freely? Or another trick to get it out? I know enough not to grab the tightly packed coil windings and try to spin it there. Do I have to pull back those 2 little magnets that ride on the shaft before it will spin? What a mess, I hate small breakable things
