- Thread starter
- #21
Mystery solved! You guys are going to either roll your eyes or shake your head, but hey, I've learned a ton in the process thanks to everyone who has contributed and especially SRGould41, who is the one who pointed out the potential (and actual) problem when I sent hm a pic after I went back and worked on it more based on the input here. The problem was I had not put the cable back in the rounded groove under the handle. After I did that, it took up the slack in the cable and was the main issue. 65swb45 also had the right idea about needing to take up the slack/create more compression, and that's what I started to monkey with and saw that if I rigged something up at the brake handle side so the cable was stretched more, it would work. That's when the pic I took of the rigged set-up made it clear to SRGould41 that the cable was not in the groove.
So basically, had I put the old cable back in the groove in the very first place after I had dismounted the e-brake, I wouldn't have spent $300 in a new drum, new brake shoes, cable and internal parts and "wasted" 3 weeks of precious time--I leave for France for 12-14 months in a couple of weeks after 3.5+ years of restoring it and not taking my troops with me
--but I also wouldn't have learned a ton of things about the whole e-brake disassembly process, the parts, how to put everything back together in the backplate, and a lot of other things related to all that. It was worth it for sure
