Dyno Expectations
Trapper50cal
TEQ Frame of Mind
Supporting Vendor
Durango, CO
Hey Guys, assuming I can FIND one, how much should I expect to spend for a master tune and break-in on a dynometer for my built 2F? Can most dynos even handle an I-6? I would like to break it in under controlled conditions and I am REALLY curious as to how many more ponies I'm gonna squeeze out of it (over the base rate of 165hp I think) Its the biggest of the 2F's (Dec.1976) and has been bored (20 or 30 over I think) It has been decked on block and head. It's running a RV MAF Cam, mid-perf valve springs instead of stock. Heads been completely gone through valve guides done and honed, rocker surfaces resurfaced, Offy dualport 4bbl, Edelbrock Performer 500 with offroad needles, 6 into 1 header (damn, they don't make 2 piece ceramic for FJ55) Soooo, more compression, more displacement, bigger cam, stiffer springs, more gas, free-er exhaust should lead to some big gains while staying dependable. I'm just super curious as to were the number will end up....240? 250? am I dreaming?
Well, it will be interesting to see. I assume you are talking HP at the wheels?
Most of the Rice tuners have dynos. I'd just break in the motor normally, retorque everything, re-adjust your valves and go to the dyno.
Ed
actually I was wondering about a bench dyno that I could use prior to installing the motor...oh yeah, and the crank was turned and balanced....I plan on having it assembled by a guy who specializes in Toyota engines (specifically 2F's) and hitting the dyno before dropping it in, just seems to be the easiest way to dial it in as far as optimizing performance (timing, fuel mixture) without having to work on a truck with 5.5 inches of lift and 34's.
$ounds 'Spensive, but I guess now is not the time to try to save a buck;)
Will it run on 87 octane or did you raise the compression too much?
I'd be more interested in the torque. Lots down low in the rpm range. Well what little rpm range there is.
yeah yeah yeah
LMAO :P, I realize I'm not building a 7sec. 1/4 engine here but it would be nice to know how much over stock I am. The compression increase will be minimal as it is deck based only w/ stock pistons so I could run regular ole regular but I always run premium anyway. I have found that carbs don't like the cheap s***.
And yes I think a 2F CAN turn a dyno-Part of owning a Landcruiser is owning the original toyota (copy of a chevy) engine. My single F gave me 350,000 miles before I blew the exhaust valve on cylinder #5. I would not trade that dependability for a SBC. I know thats a purist outlook so lets not start the original vs swap debate.
This motor is about 3 things: Torque, torque and torque.
