Hey second skin, I have a question about a competing product - and I am tossing this out there as a soft ball.
eDead 45 by elemental designs is 45 mils thick, which puts it in between Damplifier and Damplifier Lite IIRC. It is also a butyl sound deadener and self-adhesive. However, it is only costs 1 dollar per square foot, where your products costs between 2 and 4 dollars almost.
What makes your product worth the higher cost, for audio purposes and heat purposes?
Elemental Designs
I am very familiar with the edea line of products. I have each of them in my shop.
remeber, that thickness play absolutely no part in vibration damping. Consider this:
Damplifier has a 4 mil foil and is 1.25 mm thick
Dynamat Extreme has a 4 mil foil and is 1.67 mm thick
Damplifier is thinner right? So how do you explain the fact that Damplifier and Dynamat Extreme weigh the same amount per square foot?
Yup. Both products weigh .45 lbs psf even though Damplifier is 25% thinner> This is due to the fact that we use a butyl rubber that has lower oxygen content and higher rubber content per gram. End result is a thinner product that weighs the same.
When we apply this same butyl adhesive in thicker amounts, like our Damplifier PRo product, which is 2mm thick, the total weight turns out to be .68 lbs per sq foot. So, in every square foot you get about 3o% more adhesive (adhesive that has a higher percentage of rubber) and 50% mroe foil.
Now, edea 45 (which should be called edead 40, weighs .25 lbs per sq foot. It also does not come with foil ,but with a plastic like mylar backing that is not a constraining layer.
Even if you were to do 2 layers of eDead 45 you would still not get as good of results as our Damplifier Product.
Hell, the foil on Damplifier Lite is 3 times as thick as the mylar on eDead 45.
I konw that edead has a lot of fans though. I however am not one of them.
The higher cost you ask about has nothign to do with car audio purposes. The product costs the same for us to make regardless of what it is going to be used for.
We use higher quality materials than any compaeitior, have higher rubber content in our butyl, less oxygen and in most cases a thicker, strgoner foil. It costs more for us to make the product so it costs more for you to buy it.
That is pretty much what it comes down to.
ANt
